Connecting Growatt inverter gi Wifi
Banosprof
Hi. I have a Growatt Sph5000 inverter and have been monitoring it without any problem since installed. I have had to change my Wi-Fi network and cannot see on the Shinephone app or on the Web server page where to connect the inverter to my new Wifi. Help please? How do I change the Wi-Fi network used by the Growatt inverter Wi-Fi monitoring? I guess I could go back to the very start and scan the QR code on the system but would I then lose all historical data and would the Growatt server get confused? Thanks.
1. Open the Shinephone app and choose "Plant" from icons below
2. Choose the "+" icon on top right and choose "Datalogger list" from drop down list
3. Choose the Datalogger you want to configure
4. Choose the "Datalogger Configuration" from the drop down list
5. Select the "Standard Mode" and proceed to configure your WIFI for the datalogger
I'm having issues with my ShineLink-X. When I open Datalogger Configuration, all it has is 'NOTE In order to ensure the stability of the monitoring... attach to datalogger suction cup antenna on the metal'
There is no antenna. ?????
