Familymandan
- Dec 11, 2020
- 27
Hello, I did my own solar system design and install. I have 48VDC.
Batteries: LiFePO4, 3 separate banks of 3.2VDC x 16 in series. 272 ah each. On each battery I have installed JK B2A24S15P BMS.
All 3 banks/BMS are in parallel wired to +/- bus bars.
I have 5 charge controllers, also in parallel, each wired to +/- bus bars.
I have a Sigineer 12kW inverter, also wired to the same +/- bus bars.
All of the + are tied together, all the - are tied together.
My purpose of 3 banks is to increase the Amp Hours of storage
My question(s):
Do I have to do anything to the BMS to make them work in parallel? Programming, wiring....?
I don't see any setting in the software to set a slave/master...
Will each BMS charge/discharge from it's own battery bank as it needs, not caring about the other 2?
I want them to charge/discharge relatively evenly with one another.
Do I have to do anything different to get all 3 banks to work as a 48VDC - 816ah battery?
I previously used (3) Daly BMS systems in the same manner and the system only used 1 of the battery banks. It would charge/discharge from the same bank every time. Never even looking at the 2nd/3rd bank. The inverter voltage would read the voltage from the 1st bank only. The other 2 could be full but if the 1st battery was low, game over.
Questions/comments???
My question(s):
