Sverige
A Brit in Sweden
If considering connecting a generic cheap off grid (not grid tie) inverter to house wiring, would it be safe to make a permanent connection between inverter neutral and house (mains) neutral and then just switch the live lines?
In this case, the inverter neutral would always float at the same potential as the house mains wiring and individual house circuits live lines to living room, dining room, etc would be switched via relays such that the mains connection disconnects from a circuit before the inverter live is connected to that circuit. Hardware interlocks would be used to ensure the relays connecting mains and inverter cannot both be on simultaneously.
If strapping the inverter neutral to the house wiring neutral is not going to work, I would need to switch that line via further relays I suppose.
