HI,
I have a Casita travel trailer. I use an Eco-Worthy 120 W solar panel to keep the battery topped up when I'm not using it, since my storage spot doesn't have access to AC.
My solar panel seemed to work perfectly as long as I was connecting it directly to the battery posts. However, I got tired of moving the battery every time I needed to connect the solar charger. I wired the solar panel to a truck-side 7-pin connector so that I could just plug it into the trailer's 7-pin connector. This seemed to work at first, but after a day in the sun, the solar panel charge controller began showing random voltages ranging from 10 to 20 volts that changed every few seconds. Now, the controller does the same thing when I connect it directly to the battery. It looks like connecting the solar controller via the 7-pin connector ruined it.
My theory is this:
My theory is this:
- There is a charge controller built into the trailer's wiring, so connecting via the wiring harness meant that there were two charge controller in the same circuit.
- The trailer's built-in charge controller prevents over-charging while towing, so it should work the same way when connecting a solar panel to the 7-pin connector.
- Once the battery neared full charge, the trailer's charge controller was switching the circuit on and off, disconnecting the solar panel charge controller from the battery.
- The solar panel owner's manual says not to connect the panel to the charge controller without first connecting the battery
- The switching on and off of the trailer charge controller while the solar panel was "hot" destroyed the solar charge controller.
- Does my theory above make sense??
- If it does, would it be okay to just throw away the failed solar charge controller and connect the solar panel directly to the trailer 7-pin connector, relying on the trailer's built in charge controller to prevent overcharging of the battery?
