Leo3
Solar and Wiring Newbie
- Jun 13, 2020
- 170
If you have an external 30amp female outlet on an RV, could you create a splice into the wires inside where the 30amp outlet enters the RV (between the outside outlet and the converter/12V panel) and create a new 30amp or 15amp hookup inside to plug the AC200 or whatever into, so that the AC200 can be inside? Does that make sense? The RV doesn't know if you're hooked up outside or inside, or if you're plugged into a portable power supply or shore power from outside. So could you create an outlet or a male cord inside that you could plug into the Bluetti inverter. Really in the end you'd need a male plug to plug into the AC200, and maybe a male plug to plug into the newly created outlet. A male to male extension cord? Is that a thing?
