Connecting solar panels to Bluetti AC200P and Max
fdwlaw
Hello
I have 8 (eight) Rich Solar panels (please see attached specification) and wanting to connect to Bluetti AC200P, or AC200Max.
a. The voltage and amp maximum input for the AC200P is 150V and 12A.
b. The voltage and amp maximum input for the AC200MAX is 145V and 12A.
1. What is the best way to connect the panels together to get the best results?
I connected all 8 in series and get over 150 volts which would be too much voltage for both units.
2. Can I put 2 sets of 4 panels in series and then parallel the 2 sets of 4 panels….would that work or would the amps be to high?
Thank you so much for you help and advice!
DaGoose13
4 in series that are in parallel should get to around 10.76 amps at around 92v if my math isn't wrong.
