DustyDesertDweller
Hi, I have a couple questions. Someone near me is selling two 3000EHV-48 for a total of $1k and I'm interested in using them to power an off grid property. I'd like the option of powering two separate mini splits, and two fridges at the same time. I figure a 6000w inverter should do the trick but will two 3000EHV's connected together give me 6000w of inverter power? Ive read the EG4 6000XP is unable to do 6000w of 120v so it makes me curious if two 3000EHV's suffer the same flaw. I'm also curious if I can set up the two 3000EHV's to operate in 120v only and not split phase as I have no use for 240v. If so I wonder if my 120v inverter generator would be able to charge my batteries via the two 3000EHV's. I have read recently that a 120v inverter generator can only charge batteries via the 3000EHV if it is not split phase but I'm unsure if it is possible to get 6000w of 120v out of a pair of them without setting them up split phase/240v. Any help would be appreciated. Thanks
