I’m having an issue with charging and discharging that’s driving me nuts. I built a 24v system recently that worked well for a day. Now I’m not getting the same results.
Day 1, I was able to solar charge my battery while discharging. I hooked up my car to the inverter. I spent a few cloudy days charging my battery back up. I tried charging the battery with a plug in battery charger, but it would never go past 27.6v when the charger was hooked up. I noticed on the app that the battery would read ~29.2v when I cut the charger on (Even though it would push no current). But it would quickly go back down to 27.6 when I cut it off.
Today, I’m having the same issue with my mppt charge controller. It reads the battery as high as 33v sometimes, but usually settles around 29.2. But when I cut off the panels, it drops down to ~26v. My inverter keeps cutting off because it’s not getting enough from my battery and solar since the controller and even my charger thinks the battery is full.
What is happening?
8s 280ah
8s 200a bms
60a mppt solar charge controller
Victron Blue Smart 24v charger
What is happening?
8s 280ah
8s 200a bms
