Jasonoski
I was given a 36V Dakota 60ah LiFePo4. Was told the owner bought it new, used it once and then put a lead acid charger on it. The over voltage burned out the BMS and it registers no voltage at the terminals. Dakota won’t warranty it so he gave it to me.
I would like to use the cells to build a 12V battery as all my current needs are 12V.
First question:
Should I just replace the BMS and use a 36V to 12V converter or reconfigure the cells to 12V and use a 12V BMS?
I’ll need BMS recommendations too. Must have Bluetooth, temp cutoffs and heater control since I use my batteries in Wisconsin winters.
Here are pics of how far I’ve gone into it. Advice on tear down is also appreciated since this is my first time opening a LiFePo4.
Thanks,
Jasonoski
First question:
Thanks,
Jasonoski
