My current battery bank is presently 24VDC and am giving thought to ordering a DIY box similar to this one the link and reconfiguring the internal battery cell connections similar to this schematic. Instead of using their included flexible-bus jumper to series connect both battery groups I would instead fabricate my own welding cable jumper to parrallel the two battery groups for 24V. If I ever went to a 48V system, then all I would need to do is change the battery bus bar connections back to their original 48V design. My guess is that the included BMS would still connect as normal or am I missing something?
szxhbattery.com
48V 16S 51.2v DIY Unit BOX Vertical Built-in JK BMS 10KWH 15KWH 16KWH 17Kwh 16S LFP Battery 200A Inverter 2A Active Balance BMS stackable type 10KWH 15KWH 16KWH 17Kwh 16S LFP Battery 200A BMS
48V 16S 51.2v Server Rack DIY Unit BOX Built-in JK BMS Inverter 2A Active Balance BMS stackable type 10-15Kwh 16S LFP Battery 200A BMS,
