Thank you so much - sounds like problem solved!Correct.
They will be fine.
Thats a good Idea, I already have a clamp ampmeter, I'm going to do that.I bought a $60 clamp on meter that measures DC current, clamped it around the wire feeding my starter battery, and recorded a 21 amp draw, at idle, with no accessories on.
Thereafter, I progressively turned on each accessory, such as radio on high volume, turn signals, head lights, wipers, heater fan on high, air conditioner on high, etc., until I recorded a cumulative draw of 70 amps. Consequently, on an ultra conservative basis, I had approximately 27 spare amps of capacity, at idle.
My nightmare scenario is to be on a dark rainy night, in the mountains, on a narrow two lane highway, pulling my 16 ft trailer and having my alternator fail.
Yeah but PD floats lithium at 14.4V and that is a LOT higher than i ever want my battery, let alone float.Lithium Progressive brand upgrade to that POS. They are well known for never getting into higher voltage levels the Lithium prefers.
did you check with best converter? I know they had a "modified" Progressive version they sold?Yeah but PD floats lithium at 14.4V and that is a LOT higher than i ever want my battery, let alone float.
If they offered a configurable model, i would upgrade from my PD4645.
And agree, the WFCO i replaced was nothing but trouble with deep cycle lead acid.
Happen to have a link? I cannot see anything "modified". Search, including google, reveal nothing that looks like what you are describing.did you check with best converter? I know they had a "modified" Progressive version they sold?
I would call them.Happen to have a link? I cannot see anything "modified". Search, including google, reveal nothing that looks like what you are describing.
Yes, i have seen that. Its either a lead acid profile (which my PD4645 has) or you switch it to lithium and it floats at 14.4V which i have absolutely no interest in (nor should anybody else in my opinion).IRC, one of their units had a switch for Lithium.
why not?Yes, i have seen that. Its either a lead acid profile (which my PD4645 has) or you switch it to lithium and it floats at 14.4V which i have absolutely no interest in (nor should anybody else in my opinion).
LiFePO4 should not be floated or held at that high of a voltage. At that voltage, i would expect to have runaway cells and unfortunate BMS disconnects. I see no reason to charge right up to the theoretical limits before they are damaged.why not?
Zamp solar charger sits at 13.4v and never seems to stop feeding electrons to the battery. I just turned my 120v charger on as we have gone a couple of days with very little sunlight, and it's expected to continue. Currently at 13.6v and 250W (smart shunt), which is interesting as it's a 60a charger.LiFePO4 should not be floated or held at that high of a voltage. At that voltage, i would expect to have runaway cells and unfortunate BMS disconnects. I see no reason to charge right up to the theoretical limits before they are damaged.
Heck, i only ever charge any of my LiFePO4 batteries to 13.8V (3.45Vpc) to get to 99% charge. Hoping these last many many years too.
