I've got a Victron SmartSolar 150/35 charge controller, charging a 24V battery system. I've been running a single string of four 100W panels in series and it's doing pretty well with that. But I'd like to add a second string in parallel. Tried it yesterday and it was getting 805-825W. Ran for a while and then I checked the temperature of the CC. It was hot. So I split up the two strings between two different controllers again.
The system is in a shed that gets pretty warm in the summer (Houston heat). The unit is mounted on a piece of plywood with everything else. Is there any good (easy) way to cool it? I've got a small fan blowing on it now, but that sits on a shelf next to the setup. Thinking about a muffin fan mounted on the back of the plywood and blowing through the fins on the back of the unit. But I'll have to remove everything from the wall, cut the whole, and mount the fan on back, then re-mount everything. Any other good ideas?
