How do I set the correct parameters for my batteries to drain all the way to 10% and then start putting energy back into the batteries?
Current parameters and specs:
Victron Charge controller MPPT 150/100
3x HQST 190-watt panels
2x 200 amp hour lithium-ion batteries from SOK
Absorption Voltage: 14.4
Float Voltage: 13.6 (I don't need this I'm told? If so, how do I remove it altogether? Cause when I enter in O the default is 8V)
Charged voltage: 13.6v
Yesterday when I reached a 100% SOC with the solar, the controller switched to absorption mode which trickled down and switched to float, by then it was the end of the day.
Ran my Maxx air fan all night, and woke up to a 95% SOC but the charge controller was in bulk mode. How do I prioritize the batteries to be used first before being switched back on to bulk mode, as I understand this is the correct usage for the batteries?
Thanks for any and all help!
