Good afternoon all,
I'm after a bit of advice on calculating the correct charge voltage and current for my new build Lifepo4 Battery. I've read too many differing bits of information and I am now really confused!
I have a load of K2 Energy 26650 cells (3.7ah - 11.84wh- data sheet attached), 120 of them in fact. I'm intending on creating four parallel banks of 30 cells to hopefully give me a 111ah 12v battery (3.7ah x 30) x 4 in series)
The recommended charge current for each individual cell is 1.8A (Max operating charge current of 3.7A) and the recommended charge voltage cutoff is 3.65v (Max of 4.1)
So the voltages are simple (I think), and I should set the controller to charge each cell bank to 3.65v before connecting the four cell banks in series to create the '12v' battery. After that (and the battery having been discharged) I change the charge controller charge to 14.6v... Someone please confirm if that is correct? : )
It's the charge current I am confused by... I presume the charge current gets shared by each of the cells in the parallel cell bank? So I should charge each cell bank of 30 cells at 54A (max of 111A) and 3.65v? Am I correct on that?
What about when the battery is then put together and then discharged? Do I carry on charging at 54A and 14.6v??
I would really appreciate if someone could help me out with confirming the correct levels in order for me not to damage the cells & battery! : ) I've spent a bit of money on this now and don't want to damage anything.
PS. I have a 120A BMS on order to manage the battery once built.
Thanks for reading!
Charlie
Thanks for reading!
Charlie
