New DEYE 12K hybrid split-phase system, with Zero Export to CT. No battery yet. Green Normal light is on as are AC and DC green lights.
I had to extend the CT wires. I did that by adding (without cutting) about 4 m of twisted-pair network cable.
Problem: Plenty of DC Volts but almost no Amps.
Three strings of 8 x 585W PV modules, but maximum watts I've seen from each string is 52 Watts. Mostly just one string has any amps and generally about 25 Watts.
The Voc expected from each string should be about 46.6V * 8 = 372.8 and I'm getting about 330V
I guess in theory, I should check for poor MC4 connections, but all three strings are weak. Number 2 string consistently produces the most at about 25W only.
The other two string are mostly 0W but sometimes 1 or 2 watts. The most I've seen was 52 Watts from each string, at the same time. That lasted maybe a couple minutes.
I've checked all the connections except those on the roof.
What should I be doing to troubleshoot this?
