Hello, I’m confused on the correct settings for low volt protect and low volt restore. I am connecting a low frequency ampinvt 3kw 12v inverter to two parallel Ampere Time 12.8v lifePo4 300ah plus battery linked to items and info. I’m attaching the specs I have for the battery below. Could anyone tell me what the correct low volt protect and low volt restore settings should be? The ampinvt inverter uses this language which doesn't correlate to language on the battery specs. Also, the low voltage restore setting doesn't seem to allow below 13.4. or maybe if someone can help me understand what these two settings even mean, I think everything else is pretty straight forward.
Hoping soemeone who understands this can give me a definitive answer before I plug in the batteries.
Thanks for any help! Steve
