There may also be additional concerns. How much are you willing to spend. This is a list I started just to put together the most basic setup for a trailer/van with an all in one. No wiring is added here yet and you probably don't need an AC/DC distribution panel but you get the idea of how it adds up. I didn't add product links here to save space.Let me ask that in another way: if I follow Will Prowse's blueprint here: https://www.mobile-solarpower.com/the-classic-400-watt-rvs-vans-buses.html, and due to the lack of space in my trailer, I wonder if there's a good all-on-one solution that will cover at least the MPPT controller+Inverter+ATS parts of it, and that are still 12V?
The PIP1012LV-MK can be found here at least AIO
Usage | Item | Price | Quantity | Total |
All In One inverter/charger | PIP1012LV-MK – 12V 1kW 120V Inverter , 1kW Solar Charger 60amp shore | $632.00 | 1 | $632.00 |
Battery | Ampere Time 12V 200Ah Lithium LiFePO4 Battery * NO LOW TEMP | $659.99 | 1 | $659.99 |
Battery Monitor | Victron Energy BMV-712 Smart Battery Monitor (Grey) | $206.55 | 1 | $206.55 |
DC panel battery disconnect | Victron Energy Smart Battery Protect 12/24-Volt 65 amp (Bluetooth) | $59.50 | 1 | $59.50 |
Chassis to house charger | Orion-TR Smart 12/12V-30A Isolated Charger | $220.15 | 1 | $220.15 |
Solar panels | Newpowa 160W(Watt) Solar Panel Monocrystalline 12V High Efficiency PV Module | $163.90 | 2 | $327.80 |
AC/DC Distribution panel | Progressive Dynamics PD50K3Q2GP Panel Converter | $75.15 | 1 | $75.15 |
PV disconnect | DC Disconnect SI32-PEL64R-2 | $61.00 | 1 | $61.00 |
DC breaker for Orion at chassis battery | Blue Sea Systems 7035 187 Series | $45.94 | 1 | $45.94 |
MRBF fuse holder | Blue Sea Systems MRBF Surface and Terminal Mount Fuse Blocks | $41.78 | 1 | $41.78 |
Fuse for batt and MPP | MRBF Terminal Fuse 150a | $16.20 | 2 | $32.40 |
Fuse for Orion | MRBF Terminal Fuse 40a | $15.48 | 1 | $21.09 |
Negative Bussbar | MaxiBus 250A BusBar - Four 5/16"-18 Studs | $45.00 | 1 | $45.00 |
$2,428.35 |
