JOSH m
Hi folks, new guy here.
I'm looking for thoughts or suggestions on my current homestead project.
We heat our home and domestic hot water with a outdoor woodboiler.( Legend 6240 with 325 gallon capacity)
I'm adding 2 Gear solar 24 tube water heaters to the wood shed roof. I'd like to heat the wood stove jacket water through the summer months and possibly into the fall/spring transition months.
Im open to suggestions on a 12v pump/PV setup to circulate water. And should I run these in series or parallel? I'm looking at 12 foot total rise on 3/4" pipe. Will 48 tubes be enough to bump 325 gallons from 120 degrees up to 150 degrees on summy North Carolina afternoons?
I currently burn wood year round with aquastat set to 175 degrees. I have a recirculating pump on my electric water heater. When temp drops to 130 degrees, the pump circulates water from water heater through a coil in the wood stove water jacket and back to the water heater. It's pretty basic using inkbird controllers, but has been working for 2 years now. I'd just like to take a few months off from burning in the summer.
Thoughts? And thanks in advance.
