Covid discussion
"How to predict the future"
Just show me one DOI proving the Covid vaccine wasn't effective rather than continue to provide misinformation.
I'll do so much better than this!
Here's a well written paper about an anti-coronavirus vaccine that absolutely convinces me that this vaccine is safe, effective, fit for purpose, has positive risk/benefit, and should definitely be used. I have no criticisms to make about its methods or conclusions:
- Chicken were split into various groups, notably vaccinated and unvaccinated
- These groups were then further split, with some of the vaccinated and unvaccinated chicken receiving virus challenge from several strains, and others not receiving virus and serving as control
- All chicken that received virus were closely monitored for symptoms, their fluids swabbed at regular intervals regardless of symptoms then tested and titrated for virus to check if they're infected and if so how bad, and if they're contagious and if so how much.
Summary of findings:
- The vaccine is safe. Chicken fatten normally, produce enough eggs, and live long enough to get cooked.
- The vaccine is effective. Antivax chicken get IBV and die (serves'en right!). Vaccinated chicken mostly don't get it, some still get it but show little symptoms, they clear it up quickly and are maybe 80%less contagious The numbers are great, 80-90% effective! Prevents severe disease!
- Very positive risk/benefit (for the farmer)
No issues.
Safety and efficacy are assessed over an appropriate length of time. If the vaccine gives chicken cancer, or sterilizes them, or immunity disappears after six months, or they lose some IQ points, or anything else, we don't care.
All chicken that received virus were tested periodically and virus is titrated precisely, so there is no possibility of the vaccine turning symptomatic infected into undetected asymptomatic contagious carriers. The effect of the vaccine on transmission is precisely measured.
Great!
The problem
I'd like to see a study about COVID vaccines that meets or exceeds the quality standards set by the Poultry Diseases Department, Faculty of Veterinary Medicine, Beni-Suef University, Egypt.
Assessing safety and efficacy over a length of time appropriate for humans is obviously why it usually takes ten years. Not possible to do in a hurry.
However, they should have tested all the participants twice a week regardless of symptoms. Not doing so is unforgivable. They swabbed the fucking chicken, why not people? Thus none of these studies can say whether the vaccinated were really protected and didn't get it, or just got so little symptoms they passed under the radar, didn't get tested, weren't counted, but were still contagious. There is an important difference, because Darwin.
From the Israeli study you linked:
"Lack of active laboratory surveillance in the cohort might have resulted in an underestimation of asymptomatic cases. Data on vaccine efficacy in preventing asymptomatic SARS-CoV-2 infection are scarce, and our results of rate reductions in SARS-CoV-2 infections, which include asymptomatic HCWs, need further validation through active surveillance and sampling of vaccinated people and unvaccinated controls to ascertain the actual reduction of asymptomatic infection in vaccinated individuals."
I spotted 4,8 that used periodic testing in one meta analysis you posted. Better than nothing!
The Null Hypothesis
When the vaccines were announced, I decided to take the side of the null hypothesis: "These new anti coronavirus vaccines will work about the same as the previous ones". So I read all the trials.
Forgetting about FIV, the charitable version of this null hypothesis is exactly the behavior of the above IBV vaccine. I didn't have to invent anything, the script was already written, published and peer reviewed. Predictions from 2020:
- It will kinda work against severe disease for maybe a year (check)
- It will be very leaky with lots of breakthroughs. But it will reduce symptoms, which means a lot of undetected vaccinated spreaders (check)
- Thus it will select for resistant variants. It's a coronavirus, they do that. Every 6 months it'll pop a new variant that defeats the vaccine. (check). This also happens with IBV and the other veterinary coronavirus vaccines, but that's not a problem: you just eat the chicken, start with a new batch of chickens, and give them an updated vaccine. This can be done indefinitely as long as you start with new new chickens every time. It can't be done with humans.
- When vaccine efficacy drops due to new variants (check) there will be a new updated dose every 6 months (check). It will not work (check), because it's not possible to easily update an immune system, you're stuck with the first batch. They will do it anyway (check) until everyone gets bored and it gets swept under the rug and replaced with something more exciting. Check.
All the studies you posted more or less confirm this, so I see no reason to comment on them further.
I tested Grok on this and it predicted how the entire pandemic went from first principles. It's not hard.
If the virus comes out from where it came in, it will evolve to do so as efficiently as possible. Covid Classic Wuhan wasted its time infecting lungs and killing people. Omicron got smart and infected the upper airways instead while keeping the carrier healthy enough to get out and spread it.
Thus Omicron got Darwin's blessing and won. The predicted trajectory was towards progressively milder variants, and with each new variant roll a dice and get a small chance of "keeps the carrier healthy long enough to get out and spread it, then two weeks later you drop dead, or it kills half your brain cells, but you already spread it so your death has no fitness cost to the virus."
Thus I still had to get immunized somehow, at the lowest possible cost.
It's called "serial passage". You cultivate virus in a very specific organism repeatedly, so it evolves to adapt to that organism, at the cost of losing fitness and virulence in other organisms it has not adapted to.
As expected, the variant specially adapted to infect the vaccinated lost its ability to make me really sick.
Thus, mid 2022 I opted to get BA2. Three days of the sniffles, done.
Few months later I had dinner with friends. In front of me at the table: 3 people, 8 doses, 9 COVIDs (3 each). They coughed and snotted abundantly. There was so much virus floating I got hay fever. Next day I woke up in great shape and rode 100km on the bike. They took 3 weeks to somehow crawl out of bed.
Engineering is applied science. It's not complicated.
With the declaration of the pandemic that changed the world in March 2020, an army of thought police descended upon populations worldwide. Overnight, the public face of science was transformed from a civil and civilian endeavor into a matter of law and order. In place of what had formerly emanated from research communities came edicts from government officials, bolstered by celebrity bureaucrats, enforced by censorship, smearing, and coercion, and backed up by riot squads (e.g. here, here, here, here, here, here, and here). In the process, science as previously known, a careful product of time, hypothesis-testing, collective critique, and pertinent subject matter expertise, gave way to The Science™, a kaleidoscopic, ever-changing and capricious set of pseudo-medical justifications for government overreach and violations of citizens’ rights, riding on rolling waves of public messaging and manufactured fear, in keeping with a totalitarian model.
From the earliest days, there were those who could see these developments as dangerous, and those who could not. There were those who saw that the sharp turn away from democracy, due process, and human rights had nothing to do with empirical science whatsoever. And those who did not. The former have been mystified by the latter, and increasingly so as time has passed. Why can’t they see what’s going on?
The problem cannot be solved by the violent elimination of an evil elite. The essence of the problem of totalitarianism lies in enormous mass dynamics. This means the elimination of totalitarian leaders will be to no avail; they are utterly replaceable (p. 139).
This is true if the predatory practices of the present capitalist system remain intact. But given the world-historical events that have unfolded since 2020, this is far from certain. The ruling class appears intent on replacing present forms of capitalism with technocracy — a system of direct bio-digital enslavement that does not rely on secondary forms of control such as debt slavery (Broudy & Arakaki, 2020; Fitts, 2022). In the opposite corner, a rapidly awakening global population will surely have other ideas.
Nothing wrong with attempting to be civil. It's what the forum owner wants.
There is no point in being civil with the Covidians. There is zero point in any attempts at genuine dialog. That's not why they are here and we already know what they think. We already know what program has been uploaded into their brain.
Chicken studies? Well, at least you're saying the vaccine is safe & effective... for chickens... so I guess we're making some progress. ;)
So the chicken study from Beni-Suef University is designed for agricultural outcomes (e.g., egg production, slaughter timelines), not human public health. Human vaccine trials prioritize safety, efficacy, and transmission dynamics over much longer and more complex timelines, under stricter regulatory scrutiny. Comparing the two oversimplifies the issue and ignores key differences in biology, disease impact, and study goals.
You raised a point that COVID-19 vaccine studies are flawed because they didn’t test all participants twice weekly, potentially missing asymptomatic cases. While active surveillance would be ideal, it’s logistically and ethically challenging in large-scale human trials, unlike with chickens (although lawyers may now be wondering how to get chickens as clients). Still, a number of studies you probably don't know about did include regular testing or addressed asymptomatic infections. For example:
  • 10.1056/NEJMoa2034577 showed 95% efficacy against symptomatic COVID-19. While not primarily designed for asymptomatic detection via universal frequent testing, it did collect data relevant to overall infection.
  • 10.2807/1560-7917.ES.2021.26.41.2100920: This meta-analysis included studies with varying testing protocols, some incorporating periodic screening. It reported significant effectiveness against *any* SARS-CoV-2 infection (including asymptomatic) and very high effectiveness against hospitalization during the Delta wave.
  • 10.1001/jama.2021.20996 (Israeli study): Acknowledged limitations regarding asymptomatic surveillance but still demonstrated high effectiveness (92%) against documented infection, alongside strong protection against severe outcomes based on national surveillance data.
Regarding the idea that vaccines might create more asymptomatic carriers: While breakthrough infections occur, the available evidence suggests vaccination actually helps reduce transmission potential. Studies like 10.1056/NEJMoa2110345 found that vaccinated individuals generally had lower viral loads and cleared the virus faster than unvaccinated individuals, which typically means a lower likelihood of spreading it. I know these don't fit with your narrative, so I urge you to examine them.
The Null Hypothesis
The null hypothesis is a foundational concept in statistical hypothesis testing. It’s a statement that assumes there is no effect, no difference, or no relationship between variables in a study, serving as the default position to be tested against an alternative hypothesis.
Your “null hypothesis” based on veterinary coronavirus vaccines (like IBV) assumes human vaccines would follow the same pattern: partial protection, frequent breakthroughs, and rapid variant-driven obsolescence. This oversimplifies human immunology and vaccine technology. Unlike IBV vaccines, mRNA and adenoviral COVID-19 vaccines elicit broad immune responses (T-cell and antibody), offering robust protection against severe disease, even with variants. For example:
  • 10.1016/S0140-6736(22)00153-5: Systematic review showing sustained high effectiveness against hospitalization (80-90%) across variants, despite waning protection against infection.
  • 10.1056/NEJMoa2119451: Heterologous vaccination maintained 86.7% effectiveness against severe outcomes during Gamma variant dominance.
Your predictions (leaky vaccines, variant selection, ineffective boosters) do align with observed trends, but you overstate their implications. Variants like Omicron emerged due to global transmission dynamics in both vaccinated and unvaccinated populations, not vaccine-driven selection alone; unvaccinated populations also fueled mutations. Boosters, while imperfect against infection, significantly reduced severe outcomes as you can see from 10.1016/S0140-6736(21)00448-7.
The claim that updated vaccines “don’t work” ignores evidence of restored protection against hospitalization and death.
As you've said, it's not hard to bamboozle Grok. AI models like Grok generate responses based heavily on the information and prompts they are given. It's possible to steer their output towards a specific conclusion by framing the input or the assumed "first principles." It's probably why @Bongbong is always careful to show his prompt, it allows people to validate he's not gaming the response.
BA.2 became globally dominant roughly around March 2022 and remained the primary variant until June/July 2022 when BA.4 and BA.5 took over. During BA.2 some 400,000 died, out of 8 billion.
It sounds like you had a relatively mild experience with BA.2, and it's understandable to draw conclusions from personal experience. However, individual outcomes can vary widely. Relying solely on natural infection for immunity carries significant risks (like severe disease, long COVID), and these risks differ greatly from person to person.
Population-level data consistently shows higher risks of severe outcomes for unvaccinated individuals compared to vaccinated ones. Furthermore, studies like 10.1056/NEJMoa2118946 indicate that 'hybrid immunity' (vaccination plus infection) often provides the broadest and most durable protection. While it's great you recovered well, anecdotes don't provide the same level of evidence as large-scale epidemiological studies when assessing public health impacts and vaccine effectiveness across populations.
You mentioned viral evolution and the observation that Omicron tended to be intrinsically milder. While viruses certainly evolve, the reduced average severity of Omicron doesn't necessarily mean vaccines failed or were ineffective. In fact, vaccination played a crucial role in mitigating the impact even of milder variants like Omicron, significantly reducing hospitalizations and deaths compared to what might have occurred in an unvaccinated population (supported by data like 10.1016/S0140-6736(22)00153-5). The overall evidence points to vaccines having saved millions of lives globally (10.1016/S0140-6736(22)00829-5).
The studies I’ve cited—unlike the poultry analogy—address human outcomes with large cohorts, controlled designs, and real-world validation. Dismissing the larger and more relevant body of data just doesn't add up.
Engineering principles are indeed valuable in applied science. Public health and vaccine evaluation also rely heavily on applied science, particularly epidemiology and biostatistics, to interpret complex, large-scale data from human populations. Based on that data, the evidence strongly supports COVID-19 vaccines as effective tools for reducing severe disease, hospitalization, and death.
If there's strong, peer-reviewed human trial data (with DOIs) showing a lack of effectiveness of vaccines I'd genuinely be interested in reviewing it. But without them, I strongly suggest you challenge yourself to fairly examine the data. You know the long-term gold-stand tests are all showing high efficacy of the vaccine and that there's nothing pointing to them not working... isn't it time to say "well, hmmm, okay they might be effective". I mean you're already there with the IBV for chickens. ; -)
I didnt know thier astrological sign. Thanks
or do you mean a cop?
either way,
What does civility have to do with those 2 scerarios?
Have I got the LEO part wrong?
LEO obviously got kicked off this website and is no longer here with that name. Murphy name went with him too. I am not sure how that worked was not involved in them getting kicked off entire website.
My best guess with Bong's manners, exact arguments and such makes me best guess Bong = LEO.
Maybe they as in Murphy and Leo were using multiple accounts. I do not know. Think they were gone before you got here but not sure as I was maybe on a 6-month vacation because of their constant reporting on everyone and me to the mods. I was merely doing what they were doing minus reporting ppl. Leo in particular was a Pot head and everyone knows how those ppl can get messed up and post ala like drunk posters. Leo admitted he was pot head nutz and then when tried to tell him pot was certified making ppl more paranoid, he disputed it. But his Trump and Covid arguments are to a T just like Bong. EXACT.
There is an actual statement from Will that this forum is self-moderated. Will has a mean streak too. He is like I was at his age, wanting to burn this shit down so he needs to be careful. Snicker.... hahaha I hate what our govt has become.
1) The lockdowns did nothing to stop the spread, they were simply destroying our economy.
2) The masks were useless and did nothing to prevent transmission of the virus.
3) The IFR of covid was a tiny 0.23%, and that’s not accounting for all the co-morbidity deaths that were falsely labeled as covid deaths.
4) The vaccines did not prevent transmission for millions of people. They did not prevent infection in many cases and numerous vaccinated people have died from the virus. Not only that, but unvaccinated people with natural immunity were better protected than those that took the vaccine and boosters.
5) Studies show that the vaccines cause dangerous side effects at a much greater rate than the CDC admitted.
Everything government officials told us during the pandemic was a lie. It was not a mistake, it was not bureaucratic confusion, it was a lie. Even after this information became available, they KEPT GOING – They kept people locked down, kept them masked and they even tried to force-vaccinate the population.
They lied about the effectiveness of the lockdowns.
They lied about the effectiveness of the masks.
They lied about the effectiveness of the vaccines.
They lied about how extensive the testing was for the covid vaccines.
They lied about the “pandemic of the unvaccinated.”
They enforced lockdowns OUTSIDE where it is nearly impossible to contract a virus.
They tried to put the population under house arrest.
They put legislation in motion in some states to build “covid camps” in the US.
In some countries, they did build covid camps, not just for travelers, but for everyone.
They conspired to suppress ample evidence linking the Wuhan Lab in China with the outbreak.
They (Government and Big Tech) conspired to use social media as a tool for mass censorship of conflicting data.
They exploited algorithms through search engines to bury any and all contrary information.
And now they are doing the same thing over and over and over again
The covid agenda and the climate change agenda are very similar in that they rely on a core fallacy. The lie is that these events are actually dictated by human behavior, and thus human behavior must be controlled in the name of the “greater good.” The idea goes beyond this, though, into the realm of collectivism; for the globalists and leftists assert that each individual action affects the lives of the rest of the population in a great and unedning hive. Therefore, every single person must have their lives micromanaged by the state to prevent some kind of chain reaction that leads to catastrophe for the precious bug colony.
This was the claim during the covid farce, and it’s also the claim for climate change and carbon restrictions. They have fabricated yet another excuse for eliminating personal freedoms. For covid it was the air we each breath out that would supposedly destroy public health, and for climate change it is once again the air we breath out that will supposedly destroy the world. Coincidence? I think not.
During the lockdowns, numerous globalists and globalist connected climate researchers publicly expressed joy at the suggestion that covid lockdowns could be useful for reducing carbon emissions. The phrase “climate lockdowns” started circulating around major conferences and in various globalist funded studies.
These studies obviously show a precipitous drop in human based carbon emissions during the lockdowns, but still do not provide any evidence that man-made emissions actually cause climate changes. This remains the underlying con game of the climate narrative – Climate researchers with access to billions in government funds and think-tank funds happily operate on the ASSUMPTION that emissions cause warming, when in fact they have zero evidence to support this position. Correlation is not causation.
This summer, the media has been relentlessly pounding the climate propaganda drum to a degree that mimics the covid propaganda of a couple years ago. The nihilistic reports of impending “global boiling” are built upon a house of cards. Almost all climate crisis claims are based on records of a little over 100 years old. The Earth’s climate history is vast and there have been numerous warming periods much hotter than today. All of these warming events occurred during periods of ample animal and plant life and without human industry to blame.
now you are onto a "conspiracy theory" that I can get behind.
It used to just be that people would watch X-Files and talk about it with friends at work. Now we have this.
If i told you, say, in 2010 that they would lock you down and make you take untested genetic drugs to be able to come to work and do groceries?
You would surely think I am crazy, yet here we are.
All of the "conspiracy theories" i posted are open secrets. All you have to do is research and stay away from MSM and "fact checkers"
Did you notice the quotation marks? Do you understand the meaning behind them? in plain English this is the first thing that we pretty much agree on at the 90% level or higher. most of what you type are truly conspiracy theories that i ignore after having done my own research.... I just choose not to argue them with you as I have determined that they are bogus, so there is no need for me to join the discussion other than as the odd prod to poke you with.
most of us knew it was a plandemic and resisted to eachs own abilities.
And yet you took the jab.
And i am not taking a poke at you.
I am saying that not enough people resisted. Everyone had an excuse. But when there is a will there is a way. I am proof of that. My megacorporation squeeezed us very hard, but there were ways for those who REALLY wanted out. So is my best buddy who is a doctor in a red state, called me crying that they are forcing the jab on him. I said take out a piece of paper and start writing what i told him. He was also exempted.
All to well. And i used them properly.
With you I am seeing a classic example of realizing some things, but refusing things that are too inconvenient to research. Like all the vaxx people being afraid to find what they suspect they will find and so they avoid the topic because it will make them feel like they have been had, and people hate admitting it above all else.
Its much easier to screw people than to make them admit they have been screwed!
