I've built several LifePo4 batteries and they have been great, a lot cheaper, lighter and last about twice as long as similar size lead acids.
I'd like to build a LifePo4 Cranking battery, but can't seem to find a BMS that will suit my needs...
I plan to use 120AH or 135AH cells.
The cranking battery will be used sometimes in below freezing temps on an outboard, so want to be able to protect the battery from the alternator. I plan to put heating pads to warm it up on cold days so it can take a charge, but still needs to protect against charging below freezing.
I need to find a BMS that is suitable for cranking (i'm assuming a relay BMS) but I can't find one with low temp disconnect.
The specs on my engine call for a battery that can provide 750CCA's.
Anybody know where I can find one?
