I have ground deployed panels. Due to a lack of experience, I bought two 320 watt panels for on the ground, the same number of identical panels that I put on the roof. I was so frustrated with shopping for panels that when I found a set that worked for the roof, I bought a second set for the ground.
320 watt panels are heavy. You need some way to keep the panels from blowing over/away and you need a way to tilt them. I made my own frame for the panels and that just added more weight.
I have a toy hauler trailer. I can store my monster panels so that they aren't in the way. But it's a chore to get them into and out of the trailer.
If I had it to do over, I would use panels no larger than 200 watts and build a minimalist frame.
I could see putting together a system where one suitcase/milkcrate is the batteries, another is the solar charge controller(s) and another is the inverter. The weight of these components adds up, hence the separation into three manageable "packages".
If you want the ultimate in portability, consider creating a system where the trailer gets power from the system by plugging the shore power cable in. That way you don't have to tweak anything in the trailer. Pull the three (or more?) suitcases out of the basement passthrough and you're done. The challenge is getting the shore power cord into the basement and still being able to close the hatch.
