Crimp battery and inverter cables without special tools $0
PV, has anyone done a resistance test between the two?
I've been searching for a paper, but just come up with 'received wisdom' from other forums - it's as bad as twatter!
It does however make sense that cold welding (bonding at the atomic level) gives a better electrical connection than wetting the copper with tin/lead.
I've been searching for a paper, but just come up with received wisdom' from other forums - it's as bad as twatter!
Why bother. Please crimp your cables and wire terminals, cuz that's what's best.
A quick search revealed:
Great article.
Well I’m disappointed. I have many soldering irons and an 80w unit yet to arrive! But really I mostly use them to join two wires. The only soldering I have been doing mostly to crimps is with the Anderson plugs.
So I will crimp and properly. At least I had this right. For crimps exposed to the weather I will still add amalgam tape.
Thanks for the very informative education guys.
I do the same, actually. First I solder. I'm quite good at it, and I believe I do it properly.
Then I give the lug (quite) a few bangs with a cold chisel. I use a piece of wood as anvil. Dent it in two places, at slight angles.
Don’t solder crimps. It’s not a good idea. Just do the crimp correctly in the first instance
There are advocates for 'die-less' crimping - because if the die doesn't fit exactly right it could be too tight causing ridges or deformation, or worse - too loose. The exact die, or a die matching your lugs, like you might get from Temco, is sure a great way to go, if not the most costly as well. If I was doing a lot of this type of work I would surely have the fancy Temco one with all the dies and their matching lugs. For a one-off, their hammer crimper does a nice job - hammer the crap out of it, it welds it. LOL And yes on the adhesive lined 3M shrink tubing - the only way to go for this stuff.
If I were doing a LOT of crimps, it would make sense to use the best tool reasonably possible, such as the $175 Temco set. But for my needs, a few crimps a year is probably all I will ever do, unless I get into DIY solar big time.
I just received a $17 hex crimp die set, which is for mm2 not AWG and we'll see how well it crimps or not soon. If poor, I also have the Temco hammer crimper as a backup (I will return one tool soon, I don't need both). I certainly won't be using a die that's too big, hence too loose of a crimp, but the worst thing I can see with a die that's just slightly too small is the creation of some 'wings' on the sides of the crimp where the two halves of the die meet. Shrink and perhaps a gentle filing to remove any sharp edges would fix that.
I also came to realize that many, if not most, tinned lugs are open, whereas the copper ones were closed. Frankly I like the closed end, and with a shrink wrap on there they are well sealed.
The lugs I just received from Current Connected are tinned and closed. Compared to the copper non-tinned closed lugs I recently purchased from a NAPA auto parts store, they seem as good if not better in terms of thickness and construction. NAPA charged $4.50 per lug for 1AWG and Current Connected charged $2.75 for 1/0AWG, but you do have to pay for shipping (which was SUPER fast).
There are advocates for soldering, but there are just too many cons, not to mention the 'work hardening' that happens where the soldered strands meet the unsoldered strands in the wire, in a mobile application. AFAIK aircraft and military assembly requires everything to be crimped.
Yeah, I'm just done with ever trying to solder battery and inverter cables again. I clearly had the wrong technique, solder and/or flux and it made a mess oxidation-wise of very expensive cable and lugs. Just not worth it when crimps are considered the gold standard by outfits like the military.
This is why everyone says crimping is the way to go.
No not everyone. I say crimping is the way to go because the end result is a low ohm, permanent connection that cannot fail without aggressive destructive intervention.
What about coating the bare strands with some oil or other anti corrosive treatment and just crimp no solder? Would dielectric grease be useful in this case?
Dielectric- the “die-“ part means it’s resistive to electrical conductivity. You want clean, dry crimps. Use dielectric grease or fluidfilm after the electrical connection is assured to lock out oxygen on the exposed area
What’s dangerous about this kind of crimp?
It is not 100% contact over the full body of the terminal cavity. Higher ohms; resistance makes heat, heat causes fires. Never mind poor performance- at the price of copper just spend it and do it right.
I mean there are hammer style crimpers, what’s wrong with this redneck version
The hammer-style crimpers are dubiously effective on just one or maybe two sizes of terminals. Plus, the die crimpers have a huge advantage (that is marginally the reason why the hammer crimpers sortof work dubiously for 1ga, 1/0ga, and 2/0(barely)): they swage the fitting barrel smaller than its manufactured shape and size. The hammer crimp crushes the fitting even sometimes stretching it. This is not 100% contact. When I use the hammer crimper I actually crimp in a few ‘stages’ to theoretically force the fitting to fold in itself before finally crushing it shut making a swage-like fit. But it’s not ideal for sure.
you've spent thousands of dollars, maybe tens of thousands of dollars and you're going to trust the most important connection in your entire system to some random screws and a sledge hammer head you found laying around
That is the best summary comment on this thread
While you can justify it to yourself to not accept a standard, SOP or best practice; the end result may not be safe, have longevity, satisfaction and long term economic value
As above!
struggling with the thought that a soldered joint isnt as good as a crimp. More contact area with solder.
Contact area is great; low resistance is another leg of the three-legged stool
never thought about (marine grade/glue lined) heat shrink helping keep moisture and air out.
Imho that is the primary reason to use it
Because you like stuff done well
I seldom crimp in one stroke, but I start the swage, and rotate 90* and even ‘odd’ fittings don’t get the wings.
I’ve always been an annoying advocate of 100% contact. A former employer was irritated that I didn’t use the heat-shrink crush crimp terminals but used bare crimps and heat-shrinked over that. But with winter road salt and summer CaCl on dirt roads I learned a long time ago what worked. Years ago a broken spring event wrecked a boat trailer’s wiring and I quick fixed it roadside with a piece of extension cord and bare crimp butt-connectors, and heat shrink over. It’s been 15 years of a lot of wet cycles and it’s still going well-I never “fixed it.”
This is good to know. I ordered a hammer crimper but didn’t end up using it. I ordered also a die set and used my mini hydraulic press (uses a regular 4T jack) and this worked great.
My intent of my OP was that since we spent under $1k on our solar system, we didn’t need the $200 special tool to do 2 crimps. Some of you have built entire off grid homes with tens of thousands of dollars of equipment and dozens of large gauge connections, so higher end fittings makes sense there.
A $16 die set ended up being all I needed, very nice crimp. But the critical replies here helped me realize that while my original redneck two screws, tape, rock and sledge MIGHT be just fine (it did work fine, no heat or other issues) it’s not really a very safe way to do it or recommend to others to do it that way either. So I edited it to correct my mistake.
