elewis33
- Feb 13, 2020
- 100
I put some Anderson connectors on several of my battery connections (to the charger, electrical distribution panel, etc) and soldered the Anderson lugs to the 8 AWG wire coming off the battery. Recently, I was told that crimping is preferred to soldering, because if the wires got hot the solder could melt and presumably disconnect.
My thinking was that soldering would provide a much more secure and permanent connection than crimping, along with improving resistance across the crimp. I understand that crimping the right size lugs on the wire, with a good/proper crimp tool is a good solid connection (a "cold weld"?) but are they really superior to soldering?
