I'm looking for a wiring diagram the current connected 150a JBD BMS. There is not a wiring guide on current connected's website. Sunfunkits (
) seems to use this BMS and wires the B- terminals with a y cable to the negative of the batteries. I am wondering about the C- terminals. In Sunfunkits video a short y connector is used to connect the negative terminal of the battery box. I am not using a battery box and I am going to a negative bus bar. Any ideas if I should make a y cable that goes from the two C- to the busbar or if I should make a short y cable and then a longer cable to the busbar?
