Firstascent
- Mar 7, 2020
- 265
Here’s the start of my compression enclosure for my EVE 280ah cells.
I know it’s still debatable whether to compress these or not, I decided awhile back I was going to compress mine. However recently after seeing how companies such as the various server rack batteries build theirs with no compression, and with warranties makes me second guess. But here I am and they’ll be compressed haha.
I’ll have two identical enclosures, 1/4” aluminum plates. The bottom and back piece is one solid piece bent at a 90° angle. The two side pieces will be welded in place, and the front piece will be tapped and bolted with multiple m4 screws which will apply the compression. It’s nice and stiff 6061 aluminum.
The width is a perfect snug fit for the cells but not necessarily compressing since that isn’t needed on the sides.
And don’t worry, the cells won’t touch the aluminum directly. I’m using 1/8” poron padding on all sides and 1/16” for the bottom.
Unfortunately I don’t know how to weld so I’ll have a local shop weld it next week then can finish the build including cutting my busbars.
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
www.mcmaster.com
