Any thoughts on mixing 135ah and 280ah batteries in the same parallel strings? It seems Andy and Will both are doing it with no issue, but they are not communicating the BMS with the Inverters, or connecting BMS together for load balancing, as that seems to be a unique function of the Seplos BMS's.
I have four of the 6.9KW 135ah Masons, and three of the 14.2KW 280ah Masons. The first 280ah BMS will be RS485 connected, with six CANBUS BMS's behind it, all in parallel. They will be connected via the JASSN busbars. I will be enclosing those in a 72 inch rack with sides and doors, with welded L brackets to support the additional weight.
It will end up looking like a larger version of what Will Prouse just built for his server rack batteries. The Inverters will be two MPP LVX6048WP's, coupled with two SMA 6K grid tied inverters. PV will be two 600V strings to the SMA's, and 2 more 600V strings to the MPP's.
I will need to test interconectivity between SMA and MPP AC coupling, which should be interesting. Anyway, I am still waiting on the 280ah masons to show up. In the meantime, I will be playing with a Vtuvia 48V 17ah 1500W Bafang G510 mid drive full suspension ebike!
