It's Will's thread so I'll defer to him, but I recommend you read the many threads here on the forum where cell compression is the topic.Maybe I missed it when my eyes glassed over with all that technical jargon, was cell compression ever mentioned as being a contributing factor in longevity?
If you have a solid 4 hours at 100% it should be fine at 14.1V, but I am still going to keep my recommendation of 14.5V for most systems. But you should be fine.Thank you . Will stick to 14.1 slow roll and keep it there , can it stay there for say upto 4 hrs plus before dropping back down after the sun goes out ?
That's the problem.It's Will's thread so I'll defer to him, but I recommend you read the many threads here on the forum where cell compression is the topic.
I think it's also safe to say "henpecking" leads to cell degradation.So it is safe to say in simple terms that Temperature and elevated charge/discharge C rates have the greatest factor on aging/cell degradation?
Kind of like the:I think it's also safe to say "henpecking" leads to cell degradation.
"Cycling near the top of charge (75%–100% SOC) is detrimental to LFP/graphite cells"Lets throw another parameter in the mix. Time at SOC. Batteries that see say only 20% cycle BUT are kept at the higher end of SOC will have much more capacity loss VS 20% cycle BUT are kept at the lower end of the SOC.
Basically that and also staying at the lower end did not have a big affect on aging.So a according to this article less than 75% SOC was best for longevity.
So I can't drive 55V, dam it!Basically that and also staying at the lower end did not have a big affect on aging.
Didn't Will's posted material say keeping the cells at a high state of charge slowed their aging process?"Cycling near the top of charge (75%–100% SOC) is detrimental to LFP/graphite cells"
"The average SOC was found to be the most critical factor influencing capacity fade for LFP cells, over the factors of temperature, depth of discharge, electrolyte salt choice or graphite choice"
Without the occasional charging to the knee and letting the balancer circuit kick in also causes issues.
I was curious about the programable delayed equalization setting for SLA/FLA being used for LPT to get it to the knee once a week and letting it sit in mid range most of the time.
That's likely false. See my post.Didn't Will's posted material say keeping the cells at a high state of charge slowed their aging process?
I was just reviewing new material. It gets the conversation going makes the thread longer and I found it interestingDidn't Will's posted material say keeping the cells at a high state of charge slowed their aging process?
combined with lots of time at full charge, I would think they would age faster. That temp is hard on your other gear too, why not build an insulated closet and put a small AC unit to keep it all cooler?That temperature graph isn't good news for Australians. My batteries are stored in a garage where temperatures in summer hover between 30-35C. A lot of that heat is generated by a 15kW Fronius inverter and 3x Victron 5000kVA Multiplus inverters which are also located in the garage. Based on that graph, I should only expect to get 4-5 years out of my cells?
Most likely it's good for longevity as long as you don't get lithium plating from charging too fast at temps too low. But at solar fractions of C rates you are probably safe. You really don't want to charge beyond 3.5v/cell near freezing or below at any C rate. Big damage happens. Here is LFP charging at -10°C. SourceI wonder if the lower than 25C temps are "good" or "bad" or unlikely to be significant to the ESS aging.
If you had the COVID vaccine then LFP 6000 cycles should be just fine.So, if I’m 60 years old, what battery do I buy and how do I charge it so we both die a peaceful death together?
Because it's a garage and its primary function is to store cars and there's no room to build a closet.why not build an insulated closet
temperatures between 68F to 86F, charge/discharge at 0.5 C rate. Balance cells every 2 months by bringing up the voltage and holding it. Run between 75% to 20%. Buy more batteries if you need more. Put a shrimp on the BBQ, open your favorite refreshment. Live long and prosper.My goodness… what ever happened to KISS…?
