zonnebloem
- Jan 23, 2021
- 8
Hello
I recently setup 12v LiFePO4 battery(289AH) with Daly BMS and under testing. For Bluetooth connection, I used SMART BMS in my iPhone. During normal operation, no issue but once low voltage cutoff occurred, I can not connect the BMS. However this is not always case. When I set the low voltage cutoff as 11.6 (2.9 per pack), it cut off at 13 volt but I am able to connect BMS. However when I set the cutoff voltage as 10 (2.5 per pack), it cutoff at 11.6 but I can not connect the BMS. In order to be able to connect BMS, I shot B- and P- or something similar action - not consistent way is found yet
All voltage are read from BMS as well as measured with multimeter in order to confirm BMS reading. So voltage looks reliable.
Anyone can help me for reliable connection after cutoff and voltage discrepancy in BMS set and actual voltage.
