Lt.Dan
Solar Wizard
Interesting. Is there anyway to filter out this waveform from the DC side?This is normal behavior for most current-measuring devices when there's an inverter involved. I don't know the Daly settings but are you able to set the cutoff delay for when the max amperage is exceeded? e.g. > 150 amps for > 5 seconds or something?
I've seen the variation in Chargery, Victron Shunt (yup!), and Orion BMS (both the "instant" and "average" values), as well as some other threads on this forum about the same phenomenon. It's not noise. It's the 120HZ waveform induced into the DC system from the Inverter.
There is no time delay for the Daly BMS, but I have a 200a model, with the overcurrent protection set to 400a, and I've never hit it.
