ari
- Nov 4, 2020
- 5
Hi all,
I have ordered from same dealer on Aliexpress 2 Daly BMS 4S 12V 200A. (with a month in between each order).
From the first order I received the R05W-FJ23.
- 4pin UART port for the BT Module, with the module plus cable
- 3pin Monitor port, with a USB Monitor cable
I'm able to use the BT module in parallel, while the PC is connected to the Monitor port.
Now I received a "R05W-FK19" version.
- 6pin UART for the BT Module and cable plus another 6pin UART USB cable.
- no such Monitor Port at the BMS
The BT Module works, however I never get the Sinowealth software to retreive data. (COM port is fine, for sure)
Any ideas about these BMS versions "R05W-FK19" vs. "R05W-FJ23" ? Is the "FJ23" newer ?
Does anybody know if the Sinowealth will run at the "R05W-FK19" along with the 6pin UART to USB cable ?
Notes:
Temperature Sensor is working fine on both (when correct configured over BT) on both.
Charge/Discharge MOS is disconnecting also correctly on upper and lower voltage limit, no issue seen here.
I just can not connect any PC software to the FK19 "version".
Andreas
Notes:
Andreas
