Kurt13rager
- Jan 2, 2021
- 3
Good evening. I'm currently working through an issue with my Daly 8S BMS bluetooth and cannot seem to pinpoint the issue.
When charging the LiFePO4 cells (or not charging), the state of charge for the bms app continues to drop and quickly. The battery voltage reads 28.8V which is accurate but the amp reading, on the app, continues to read 29.2A regardless of what is actually flowing (even when charger is not active).
I have tested each of the 9 leads to ensure the correct voltage is read and it is accurate. The B- lead is connected to the main battery negative and the P- is connected to my Victron shunt battery terminal.
Any ideas as to what could be causing this issue or how to go about further troubleshooting? I've already disconnected the BMS and leads about 10x ensuring they are all wired appropriately.
Other components in the system, Victron Multi-plus 24V 3000VA with Smart Dongle, Victron BMV-712 with 500A shunt, Victron Lynx Distributor 1000 DC, Victeon Smart Solar MPPT 100|50
Thanks in advance.
Thanks in advance.
