Hi all,
i have an setup in my camper van with a 100A common port, LiFePo4 4S BMS for my 202Ah batteries. Everything is set up properly and has been working for half a year now. Now it has started to become cold and it seems the temperature has been so low that the cut off has been triggered. This is set at 5°C.
Now even after i heated up the camper, the battery is not charging anymore (see screenshot). Do i maybe need to delete the error or should the charging resume as soon as the temperature threshold is crossed?
thank you
thank you
