Daly BMS 4s 12V250A
waiapasi2006
Hello all.
I purchased this Daly from a member here to build a battery pack. (initially 280Ah, but had to switch to 230Ah) long story.
This Daly didn't come with a manual. I searched as well, but could not find anything pertaining to the numbers below.
Daly BMS specs:
What came in the box:
From what I have read and found so far on the forum:
The cable on the far left are the balancing leads and it's to be plugged in here:
Please correct me if I'm wrong.
The temperature sensor is to plugged in here:
Where would these two others go?
I have one labeled monitor and the other is a Bluetooth adapter
On the opposite side of the BMS, there are similar inputs as well.
I read you can connect the wire labeled "monitor"
Your help would greatly be appreciated.
Thank you.
I didn't watch the whole video, but I skimmed it and it looks decent
So, as I'm researching and finding documents on the forum, I'm going to post the links in this thread.
Here is a video I just found. There are some good information in here as well. Most of it has been covered.
He does mention about the two pins that needs to be bridged @ (17:35)
