Ive got a 12v battery (280a primatic) with one outlier cell. Cells came from AliExpress, so I am stuck with them. The Daly BMS was advertised as the new model supporting BT and 485 for the touchscreen, yet I received the old model with only BT support. In my experience on Ali; all sales are final, regardless of quality of goods received or goods as described. If the cells and BMS came from Amazon or ebay, I would have returned. This is the risk of using Ali. I have a documented case for a chargeback, yet that would damage my relationship with Ali. As explained to me, chargebacks are so high my primary bank (bofa) blocks Ali from their cards. Off my soapbox to the issue...
Cells were top level balanced before installation. This battery is for my RV and what I am finding is balancing is not once and done. I am finding the battery requires continual top/bottom balancing and the Daly's 30ma balancing is inadequate. After a few cycles, my cells were out of balancing causing a ind cell over volt fault. Attempting to top level the lagging cell with the battery installed, I was unable to send any current to the cell. I should have recognized this as a clue. To augment the Dalys weak balancing, I added a Heltec active balancer. I should have recognized this was not going to work. What I found, the Heltec running with the Daly, the Heltec was only bleeding off excess voltage from the high cells to match the low cells, no current flowing to the low cells. Pulling the Daly out the equation and running only the Heltec, the Heltic balances as expected; Robinhood -- take from the high give to the low.
This 4s is a primer for building a 16s 48v hybrid system for my residence. I am not in love with the Daly. I am not in love with Ali. For the RV, not a big deal, but for my home, having to mess with 16 mismatched, purported grade A cells out of balance; unsustainable. Is my approach misguided, should I expect to sacrifice up to 20% of cell capacity rendering top/bottom balancing moot? Does continual top/bottom balancing damage the cells, negatively effecting management/longevity? Ive been wrong before...
My next step is to try adjusting section 4 balance settings on the Daly in a likely futile attempt to prevent the BMS from absorbing ind cell charge current.
Am I pumping a dry well with the Daly BMS -or- am I missing underlying cell management?
Thanks!
Thanks!
