Long post here, but need some help with my Daly 250amp BMS that’s randomly dropping output only when key is turned on.
This is being used in my Golf Cart & I tried to include all the details below.
Cart: 2015 EZGO RXV
Controller: Stock Curtis 235 amp with programming to 30 Mph
Cells: 105ah LiFePO4 from AliExpress
BMS: Daly 250amp Smart with Fan/Bluetooth from Amazon
Build of battery itself was straightforward. No issues. I top balanced all cells & configured BMS at desktop PC. I adjusted settings so BMS does not go to sleep & Bluetooth App all up to date & works great.
Everything appeared to be great… until… a couple days into use I hop in cart & turn key & nothing. I have zero volts output from BMS. The Bluetooth shows disconnected & nothing I do will turn it back on except unplugging the primary 16s balance plug and plugging it back in. Then it instantly shows full output, Bluetooth comes on & everything is fine. Once it’s up, the cart runs great. No issues with charge or discharge.
I’ve been troubleshooting this running the cart for the last 4 weeks. It does not happen every time, but has happened 6-8 times over 4 weeks. Only about once every 3-4 days and we drive the cart a few times every day usually. I got in the routine of opening the app & monitoring prior to turning the key on. 100% of the time the app is always working & the BMS is always on & showing full output voltage, SOC, etc.
In the random instances where it breaks it only does it 1-3 seconds after turning the key to the on position. Turn the key & the app just immediately disconnects & when I check voltage output from BMS with meter it’s at zero volts. It will stay like that indefinitely until I unplug the 16s cable and plug back in. Then everything is fine the rest of the day.
I’ve tried emailing Daly multiple times through Amazon as well as directly & no response yet. I’m currently running firmware version 31_220722_100T that came installed on the BMS. I’d like to upgrade the firmware if there is newer available, but I’m having a hard time finding that info online. Hardware version is BMS-GD230-309E.
If the BMS is faulty, which is my suspicion… I do still have a couple weeks left to return the item via Amazon. Has anyone experienced a scenario like this? Any ideas before I remove this? It left my wife & two young kids stranded a mile from the house & she won’t use it anymore for fear of getting stranded again.
If I return it, what brand should I replace with? I've seen quite a few folks recommend the JBD
Thanks!
Josh B.
Cart: 2015 EZGO RXV
Thanks!
Josh B.
