Thanks for the info thanks, appreciate it. Struggling to understand difference between lvd and balance.
Yes I used a 30/5 and a 30/10 to initially top balance.
I tried that but when one would be good I'd move to another and by the time I had say 8 up to 3.65 the first one would be falling to where it started and then each one after that. It was akin to painting a bridge.
My power supply is advertised as 10A but only puts out 5 at 3.65v. I've seen it go up to 10 at a higher voltage messing around with other stuff but not at that low voltage.
Is absorption the same as boost charge voltage? I'm using an eco worthy 3500 hybrid and absorption isn't a setting but boost is.
Ok so its not supposed to balance while not in charge mode. Makes sense why I never see it toggle over off of charge mode.
Reading others posts that have 16s banks it seems they can drive their banks higher while the cells staying in balance (if that's the appropriate time to use balance). I'm at .002 to .004 while in the mid 53s but any higher I loose that .002 and it goes into the .1 and .2 and bms high cell voltage kicks in when one goes higher then 3.65 stopping my whole charge.
