Hi,
My battery is connected to a 3 pole led switch. From that, i want to power accessories, for e.g. a light.
But the BMS is going on sleep mode after some time of inactivity, so i have 0 voltage (0.04v exactly) on the P- and Pos terminal.
How do you wake up the BMS for a battery power usage ? I'm not talking about charging, it will automattically wake up.
I tried to put a load : heating resistance, laptop, cordless screwdriver. None of these woke up the BMS.
I read the thread about Daly Smart BMS issues, do i always have to short the two pins or B- P- to wake it up ? It is not a normal practice, it may damage the BMS .I also have to open my box every time...
I have à 100Ah LiFePO4 12v battery and Daly Smart BMS 60A common port.
Thnx
Thnx
