Hello
I received a RS485 to USB cable for my Daly BMS 12v 4S and was happy to connect my computer to the BMS, but it fail !
I checked many time the connection of my USB cable. It's a 5 pins, but only 3 wires (White / Green Black), connected next to the UART port used for the Bluetooth module. This port is without any label or indication.
After that I connected the USB part to my computer (tested on two differents computers), and installed the CH34Driver.
The com port was ok and I tried both softwares, Sinowealth and BMSMonitor, but after connected well, no data was able to be read ...
Here are some screenshots to show my problem.
I guess some of you have solutions, since I'm not sure Daly Support will give me the solution.
Thanks
Thanks
