reptily
- Dec 21, 2021
- 1
Hello All!
After the first assembly of the battery and the BMS, everything was fine.
Then I needed to move the batteries to another location, I disconnected the BMS. And after the next assembly without load, the BMS shows consumption of 75A.
But there are no consumers, there should be 0 A. I tried to connect to the PC and update the firmware, the firmware was updated, but the problem remained. It is possible to do factory reset?
And the most dangerous thing is that the overcharge protection has stopped working, although there is a message about overcharging, but the charge continues
i'm use 8S 250A BMS LiFePo4
