LanceBuilt
Owner Builder
A few months now with my first lifepo4 battery, 200ah 16s, daly 200a bms, off grid home system.
Problem is that the bms will disconnect at inappropriate times, like when mid soc and with a mild continuous discharge. When I reboot the bms through the buetooth app it shows zero fault alarm. System is never idle, always running a 6kw inverter which draws a good 150 or more watts at idle. I am considering purchasing an overkill bms and keeping the daly as a spare, but only if there is good reason to expect that this will fix the problem. Are there settings within the daly that I may have missed?
