Lightful Mind Vet
- Jan 4, 2022
- 4
I've read through the other posts, and have basically determined that I should have gotten a different BMS. But, since I'm stuck with them for now, I'm trying to troubleshoot my 4s 12v Daly BMS issues. I have 4 sets of 4 prismatic cells (EVE 280 ah) in my RV. Everything was working fine for the first two days, and then I started getting over-voltage alarms from my Victron controller. So, I tweaked the settings of the BMS from the defaults that the distributor sent. All four controllers were set identical, but one has just stopped taking input. I can connect to it via BlueTooth, but almost all of the settings are set to "2", battery type is not set, etc (I assume this is the factory default) - but, now, it won't allow me to set/modify anything.
Here are some pictures of my setup, and screenshots from the Smart BMS app.
