ChuckNorris
- Sep 6, 2020
- 36
Real simple question. If using a 16s daly bms. When everything is hooked up properely. Does disconnecting the 1rst cell negative disable the bms. So i could then safely remove the 16 balance leads. Does disconnecting the 1rst cell negative break the circuit and protect the bms for further balance lead removal.
Normally you of course just remove the 17 pin connector and that disabled the bms. But i want to mount it in a way i won't have access to the 17 pin connector until after i disconnect the negative lead first. Then the 16 balance leads. Bc as far as i understand. If i just start removing the red positive balance leads 1 by 1 while it's on. It will damage the bms. So my thinking is that by disconnecting the negative and breaking the circuit it then makes it safe to unwire the cells. Anybody know the exact things that damage bms's?
