petee_c
I'm building a trolling motor battery for my father. He wants to use a small 30lb thrust 12v trolling motor on a paddleboat to put around his cottage.
It will be a 4s2p battery made up of 8 Navitas 25Ah LiFePO4 batteries. Max amperage it should draw is 30amps
I will need a basic BMS to make this a plug and play battery for him. Some reading suggests I should get a BMS that handles around twice the amperage to avoid problems so I am looking at 50 or 60amp BMS's.
I see these on Aliexpress. I think they should work for my application. He has a 12v battery charger for the trolling motor battery on his big boat, but it only has a lead acid profile. I am thinking about advising him to get one of these: https://www.amazon.ca/Automatic-Mai...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
The battery will likely go in a custom plywood enclosure if I can't find a suitable sized dry box. The output will be to an xt60 connector. I will put a mating connector on his trolling motor and on the charger.
I do not believe he will ever be charging the battery when it's below 5C , but I put a label on the battery not to charge it when cold. He will likely charge it in the cottage which will be fine temperature wise.
Is there a Canadian/US supplier of a Daly BMS like above? or is there one that you would recommend for this application?
