Daly high current question
chelseawaves
hey guys, planning to buy 8x EVE cells 280AH and build either :
- 1 battery, with 4 groups of 2 cells in parallel , and then mount those 4 packs in series to get a 12v 560Ah
or
- 2 batteries, 4s 12v 280Ah, and then parallel those 2 into a 12v 560Ah
for option 1# i'd go with a single BMS ~300A , monitoring only the '' 4 parallel packs'' , so that wouldn't be monitoring every cells
for option #2 i'd go for 1 BMS per battery pack ( ~ 150-200A per BMS ) , monitoring every single cells.
what would be the best option? and is this BMS a good pick? https://www.aliexpress.com/item/32921440657.html?spm=2114.12010612.8148356.4.76a330856w0LSg
i looked into the Chargery BMS but i am quite new in this world and with the DCC and relays and everything it looks a bit too overwhelming for me, i wanna keep things as simple as possible to minimize fuck ups, thanks!
nevermind, just realised this BMS is for 3.7v cells, not 3.2!
any recommendation for a good 3.2v BMS ~ 150A or a 300A ? other than chargery?
if it's any help; I went with 2 separate 12v batteries each with their own 200a daly BMS on my 5th wheel (3kw inverter). by effectively splitting the load across the two batteries it derates the daly BMS by about 2 as I didn't feel comfortable with the cabling on the BMS. each battery has it's own ICDT bat monitor for viewing the individual cell voltages.
thanks guys! hopefully i'll find the perfect one by the time i'md ready to build! i do need low temp protection even tho i'll have it with victron mppt, but i do like having it straight on the BMS, i live in canada and this is not optional
I wound up buying the Overkill 120a BMS's for my 12v RV system, because Will has tested this brand and confirms the low temp cutoff ACTUALLY WORKS. They also can charge at 120a as well, unlike some others where they can't charge at same rate as the discharge rating.
So I bought 2 of them and will just build 4s2p, to get 240a continuous... I already got them in the mail but still waiting on the 8x 280ah cells, aluminum plates, and heat pads, to come, so I haven't had a chance to try them yet...
The above is for my 12v RV system where I am going with the OverKill 120a, but I also purchased 2 other BMS for my off-grid house project for my 48v banks of 32x 280ah cells, and I used these ones (as they came with my Treeline bank):
I have almost all the parts to assemble this bank now, except still waiting on the aluminum plates, and heat pads, to come, so I haven't put it together yet either. This BMS does not support low temp cutoff, however, I got a Victron charge controller with remote battery monitor and temp sensor to cut off this set. I will run these as 2x BMS, and building 32 cells 16s2p... Unlike the OverKill which have related phone app and management, the ladder one discussing here for my 48v system does not have any BMS management functions... They are manufactured by Bellhope Technology Co... They look really beefy and well built but no management.
My Daly smart BMS has low temperature protection. I have tested it and it works
I have a 60A Daly Smart BMS. Temp cutoffs also work.
