Hello,
in my li-ion pack 16S9P I have a DALY smart bms 16S 100A with bluetooth. The week worked very well, but now that I connect via BT I see a few errors. It doesn't show me volts, temperature,.. Shows EEPROM err, AFE COLLECT chip err... All cables are good. The battery can be discharged and charged. When I turn off the discharge in the application, the battery still works. The voltage is 66V, which is ok.
When I switched the BT module from another pack, it was still a problem. So the error is in the BMS itself, not only in BT module.
I can change the settings, password in the application. I tried to reset the factory settings but it doesn't work. My settings are still there.
I don't know if there is a fault in the BMS and it doesn't work at all or in communication and it just doesn't show voltage.
Has anyone met anything like this? Is it possible to test whether balancing and protection work?
I've been waiting for two months and it's already broken. Well thank you :- (
