Hello everyone, I'm new to that forum and need help please
Got 8 x CATL 280AH (actually 272AH) 3.2v cells and a 150AH Daly BMS with Bluetooth and all are set up but need help with correct settings as default come with default setting so can you help me... run 24v system so can you help me correct parameter setting for eg i saw on first page on this thread...
1. Cell volt high protect : 3.65 Volt
2. Cell volt low protect: 2.80 Volt
3. Sum volt high protect: 14.60 Volt
4. Sum volt low protect: 11.20 Volt
5. Cell reference volt: 3.20 Volt (this is for LiFepo4 Cells !)
6. Sleep waiting: 65535 (This disable the Sleep Modus forever)
7. SOC: Set this to 100% if all Cells reached 3.45 Volt. At the end of charging, the voltage ries is very fast....
8. Balanced open Starts: 3.400 volt (Means only Top balancing)
9. Balanced open diff voltage 0.020 Volt
So can you help me for 24v setting, thanks!
