Hi All
Having a strange issue with my 250A Daly Smart BMS SOC.
I have an 8s 230MAH battery connected to it, and its all connected through a MPP solar all in one 3kw unit
The SOC gradually creeps higher and higher over several days vs the pack / cell voltage and I have to keep resetting it back (rough guess based on cell voltage when no load and discharged down to the lowest i run it to)
Its constantly charging or discharging at the moment with all the sunshine as its used to run a small crypto miner. Typically it will kick over to battery abut 9am when it hits 27v and back over to mains early evening at 24.5V (this should be around 14% SOC), over the period of a few days the 24.5V will SOC stated by the BMS will gradually increase, probably about 5% a day, every three or 4 days I reset it. I have enough solar to run the miner and charge the battery at the same time, so it gradually charges while the sun is shining and then drains the battery down in the evening.
If I don't keep resetting the battery the SOC hits 100% along time before its actually charged and the protection cuts in and stops it charging, ive seen it as high as 45% SOC @ 24.5V before I reset it.
If i look at the parameter readings it shows cumulative charge as 17430 AH and Discharge as 15589 AH, so it looks like there is a big discrepancy between what's gone in vs what's come out which obviously there shouldn't be.
Has anyone else come across this issue and has a solution?
Or is there an alternate BMS I should look at, needs to be 125A 8S and have USB connection for monitoring / changing settings
Thanks
Thanks
