IOS.Android or IOS?
Hi Alan, I'm curious how you manage to make it working. I'm also on IOS with latest update of Smart BMS app (v 1.0.6).IOS.
I tested the Android APP and can confirm i can change Capacity with a 4S Daly SmartBMS. I cant seem to change the SOC value however.I only have the iPhone app, not PC.
The main problem I have tho is I can't change the Capacity and therefor the SOC which will then give me my cycle numbers.
It is strange tho, because I have seen some screenshots showing the chemistry field filled in.
But I mainly want to change the Capacity and the SOC.
Did you disable the Bluetooth on the Iphone when trying to connect the android? Maybe it can only connect to one at a time?Well that just takes the cake. lol
I only have an iPhone so yesterday I had a friend over with a new Samsung Galaxy and I borrowed it, downloaded the Smart BMS app and it wouldn't even find my BMS. I unplugged the Bluetooth module and reconnected it several times and it made no difference. While my iPhone could connect to the BMS the Android refused to even see it.
I'm buggered if I understand what is going on.
I have ordered a USB Uart cable from eBay so I will try that on the laptop when it arrives and see if that works.
It's really weird as I can change other settings with the iPhone but not the battery capacity or battery type. I really want to get the SOC working so I can see what is happening and have the cycle count accurate.
Cheers
The great firewall blocks gmailWhy "non-gmail"?
The Daly BMS bluetooth only works with very new devices in my experience.Well that just takes the cake. lol
Cheers
Mine is the 100a but otherwise the same. It's got me buggered then.I also have the Daly 4S 12V 250A BMS and I was able to connect via BT (ios) and change only some of the settings, using password 123456 I was able to change Capacity, SOC, Chg overcurrent protect, dischg overcurrent prot... I also found the BT connectivity goes into sleep mode, I've only just purchased this BMS to go with 500a Sinopoly cells that I'm installing in my boat. I also had to use a multimeter to turn on the BMS
Yes, I even turned the iphone completely off. No difference.Did you disable the Bluetooth on the Iphone when trying to connect the android? Maybe it can only connect to one at a time?
Sorry mate, i'm in Qld, but thanks for the offer.I noticed your mobile carrier - if you are close to Melbourne i could help out with my UART cable.
I got mine from Daly on aliexpress when i ordered the BMS. Solar4rvs in Melbourne do sell them with a BMS, they might sell them separately.Sorry mate, i'm in Qld, but thanks for the offer.
BTW, where did you get your Uart cable from?
That is my last hope that I can change things via the Uart and a PC.
120Amp Smart BMS Daly 60A charge 8s 24V BT US$131 | https://www.aliexpress.com/item/4001316173097.html?spm=2114.12010612.8148356.3.31534c722yy3yO |
300 Amp Daly Smart BMS $255 |
US $4.31 12% OFF|smart BMS 8S 24V 300A 400A 500A Bluetooth 485 to USB device CAN NTC UART software Li on Battery protection Board BMS With Fan|Battery Accessories| - AliExpressSmarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
I think the PC option will work. In my case, I connect via PC to the 485 port. The Uart to USB did not work for me.Sorry mate, i'm in Qld, but thanks for the offer.
