Now I confused ;-). Never saw the option to add a temperature probe.
Which supplier does that?
For my 24 volt BMS (now it says you must order 5, it didn't when I bought it):
Daly Bms 18650 Pcb Pcba Board Manufacturing And Assembly 3.2v Lithium Lipo Ev Battery Lifepo4 8s 24v 200a 250a 300a Bms - Buy Daly Bms,Bms 24v 8s/bms 24v/lipo Battery/250a Bms/ev Battery/battery Bms,Bms 8s 24v 250a/8s Bms/lithium Bms/200a Bms/300a Bms Product on Alibaba.com
www.alibaba.com
Note, you must contact them via messenger and ask for "250 amp continuous output at 24 volts (8 cell LiFePO4) with Bluetooth and low temperature disconnect, USB interface, able to set my own voltage profiles for cell voltage"
They (Kevin Zhang) quoted me:
"The price is 140usd/pcs for 2pcs Smart BMS LifePo4 8S 24V 250A with Bluetooth and low temperature disconnect,the price includes the lightboard and bluetooth module, no need to order temperature sensor separately, The temperature sensor will be together with the BMS"
FYI, they actually manufacture them to your specification, as in they told me "5 days to manufacture, then ship via DHL"
For 12 volt BMS:
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
I chose the "250A com UART BT"
Add the USB to UART cable (for connecting to PC) and the Bluetooth module.
Mine came with the temperature sensor already attached, and indeed it seems accurate (if a short cable).
