I'm working through this pallet of cells and I found one with a decent dent in it. All the other cells were high quality, very clean, very limited scratching or very slight denting.
This cell has a dent that is approximately 4.5mm deep with an impacted area 2cm by 1cm. Should I be concerned about this? I don't care how it looks, I only care about how much more likely this one is to catch fire or take out my BMS or other cells.
Are there any tests I can do on it other than put it in a pack and try it out? It is the same voltage as all the other cells and there's nothing leaking.
